21 - 33 of 33 Posts
Rats !!!!! Cross your fingers.
Using a mechanic's stethoscope - or a long screwdriver handle jammed against an ear - each injector should sound off with a rhythmic tick-tick-tick-tick-.
If no joy with the new coil cassette and boots, try a 20 oz. bottle of Chevron TECHRON in a tank of Top Tier gasoline.
http://www.toptiergas.com/licensedbrands/
TECHRON, under several proprietary names, is a component of Top Tier gasolines.
2003 Deville Base
I had a bad experience using "Duralast" brand from AutoZone. Was bad straight out the box. I replaced both using Delphi and no issues after.
AutoZone "Don'tLast" parts are cheap and warrantied for life for a reason.
2003 Deville Base
Agreed, but at the time they only had 1 Delphi in stock, everyone else had to order. since i needed it that day i got the second coil. Returned it, Amazon next day the second Delphi :sneaky:
2000 deville
Discussion Starter #25
Coil Cassette is in with new plug boots, a little dialectric grease, new plugs, injector cleaner, etc and the car runs great! It purrs and the throttle response is something I have not felt in a long time. Thank you to everyone who replied and gave tips. I learned a lot about my Deville and cars and parts, etc. Thank you all so much!
Glad to hear it ........... another case of when blind luck and superstition wins out over skill and science :rolleyes:
2000 DTS
Great news! Glad we could help!
2004 Deville 1992 Deville 2002 Seville STS
Got the same code and it was a horribly corroded spark plug, but I also replaced both coil packs on my 04 Deville. I kept getting a misfire #1 and #7.
the 2004 Deville has a completely different ignition system than the 2000 through 2003 Deville -
How hard was it to get the plugs loose? It was recommended to me to have a cold engine. I have a torque wrench for the new plugs and am getting them from Rock Auto in a few days. I will report back after it's finished. Thanks for your input.
It shouldn't be too difficult to break them loose, my DeVille had almost as many miles when I pulled mine. Don't over torque the new plugs.
you are responding to a post that died 3 YEARS ago -
2000 deville
Discussion Starter #33
Now I know exactly when I replaced my coil packs plugs and boots.....3 years ago. Ha I am cleaning the TB tomorrow and the solenoid ( with Carb cleaner and then Electric parts cleaner for the solenoid) Still trying to get rid of the P0300 code. Driving another car while I figure it out.
21 - 33 of 33 Posts
