1 - 8 of 8 Posts
Let me know guys when u got p0300 code what was
solution to help you out?
How many change plugs and wires?
Injectors?
Coils?
Fuel pump?
EGR?
And what solve problem?
2010 DTS
Wires where my problem but changed plugs first to no avail. Having said that, I did not get a P0300 code til I induced it by brake torqueing and holding it at 2000 RPM. It started out with a chuggle that I was trying to diagnose.
1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
TomFlag said:
How you came this solution?
The dealer plugged in the Tech2 and found that 3 of the 4 cylinders on that side were misfiring. They replaced the coil pack and that fixed it. I replaced the plugs first and cleaned up the connections on the coils but when that didn't help it really didn't leave much else.
Jim
First time it was wires.
2nd time it was the ignition coil #2
3rd time it was ignition coil #3
Discussion Starter #8
I have got codes from O2 sensors, misfire. Cadi stalling, hard to start, sometimes no enought power, fuel consumption high. It was hard to know
what is problem but now finally I got p0108 MAP sensor error code.
All those problem make sense that there is problem with MAP sensor.
Because it affect inginition timing, fuel delivery etc...
1 - 8 of 8 Posts
