OK this has been annoying me for months and now that it's warming up it's time to hunt it down.
'05 STS V8, under 60K miles, runs fine drives fine starts and idles fine. Gets a P0171 and sometimes also P0174 trouble code, at seemingly random and infrequent times. Have tightened the intake manifold bolts to spec, checked all hoses and intake fittings, did the carb cleaner spray test and haven't identified any leaks. I do suspect the MAF a bit as I had to clean it once before when it acted up (also used that opportunity to clean the throttle body).
Any other ideas? I've been searching for tips on what else to check, but haven't come across an "aha!" answer. Thanks!
