2002 ESC
I just got a P1106 DTC..Intermitint high voltage to MAP sensor..What would cause this?What is the fix? It doesn't sound as if the sensor is bad to me.By that,I mean the code is not a bad sensor but rather a too high voltage in the circuit.I know that as the vacuum goes down the voltage to the sensor goes up.Suggestions?
2002 ESC
Discussion Starter #2
Nobody? I guess I need to move on..Willingness to help a fellow Eldorado enthusiast not forth coming on this site..
I's not "willingness". If no one answered, it's probably because no one had an answer. Personally, if it where me, I think I'd replace the sensor.
-Administrator- 2002.5 F55 STS 2014 FWD Explorer
??? Willingness to help ???? No good ideas or hands-on experience here, either. If you choose to "move on" then that's your call.
Just for grins I looked at the P 1106 writeup in the "All Diagnostic Codes" menu for my STS in www.alldatadiy.com. There is an extensive description and explanation text as well as diagnostic tree. The GM/Cadillac service manuals are useful in some cases.........
