1 - 8 of 8 Posts
1999 Seville STS
So with a 99 STS my coolant was low so filled it up, do I need to bleed the system or something on this thing because now it wont stop overheating. If so any one have any instructions?
Second I have this strange electrical/ac problem
Periodically the dash will ding ABS and traction light come on, then ac will only blow out of floor for somewhere between 2 mins and 5 hours. Then it will ding again, lights off and blows out of dash.
Now the abs and traction lights come on at other times too and dont effect the ac, but when ac does this they lights always do same thing
Re: Overheading 99 STS and strange electrical? Ac? problem
You had better read the Northstar Performance threads down below pertaining to head gasket failure and the symptoms. If the system is properly filled to halfway up the tank, COLD, and you're still losing coolant and "overheating" (coolant blowing out the coolant cap) and there's none on the floor or driveway (as in: hose leak or some such), you have big problems.
How old is the battery in your car?
Read the sticky thread at the top of the main page in Cadillac Technical Discussion, Technical Tips, "How to pull codes on ........98......." . Use the OBD-II code lists. Don't clear your codes yet - come back here.
Go up and read the entire Cadillac Technical Archive at the top of the page, in the black bar.
'98 STS (RIP @ 206,xxx miles)
The cooling systen is self-purging but the purge plumbing must be flowing freely for that to happen. Easy check is to remove the rubber hose from the top of the coolant reservoir and verify that there is a coolant flow from the hose (engine cold at idle)
Too many unrelated things going on here.
Display your trouble codes and let's see if we can find some clues. Here is how to display the codes;
http://www.cadillacforums.com/forums/cadillac-tech-tips/172511-how-pull-codes-98-04-sevilles.html
1999 Seville STS
So if those are all active codes Im going to be busy....
B1327
U1300
1064
1255
B1652
1983
U1301
B1343
1652
P1574
1602
1604
1644
U1040
1255
C1736
1780
1783
1785
You better get your overheating problem sorted out first...
1999 Seville STS
Yup looks like about a gallon every 4 days... no signs of coolant leaks on garage floor so guessing head gasket..
Time to sell and get another one?
Decision time........Even if the rest of the car is mint it isn't worth a plugged nickel on the market. If you really like the car, fix it and enjoy a LOT more time in it - if you've had it with expenses, unload it and look elsewhere. No easy shots to call here - the cost of a newer/different ride will be even or more than the engine top overhaul.
2016 Honda Accord LX. Previous: 2004 Deville, 2000 STS
If the car doesn't have any other major issues and is in good shape I say fix the motor and just keep her on the road. Buy Jake's (look in Northstar section for details) stud kit and fix the motor yourself or either truck the car up there to him and let him do it for around $1500 (+/-). Dealer cost for the same job is around $4000.
Here is the website for the kit: http://www.northstarperformance.com/
1 - 8 of 8 Posts
