95 Fleetwood Brougham / 01 DTS / 11 CTS Lux / 11 DTS Platinum
I'm planning on mounting my Sirius radio above the right side of the rear view mirror. I intend on using power from something in the overhead console.
How does that console come apart?
Discussion Starter · #2 ·
OMG ? Why is this post multiplying ?
1989 Fleetwood FWD / 2000 ETC / 2000 STS / 2006 STS V-8 1SF RWD
Hello...
Instructions for 2000 Seville
(yours should be similar)
REMOVAL
*Do not let the overhead console hang from the wire harness
1. Carefully pull down on the overhead console to release the four retainer clips
(Illustration shows using a screwdriver on the forward bottom left corner)
2. Disconnect the flat wire electrical connector
3. Disconnect the cell phone microphone connector (if equipped)
4. Remove the overhead console
Hope this helps...
Post back your results.
Thanks. So just give it tug huh. OK I'll give it a whirl.
Discussion Starter · #6 ·
Just wanted to post back and confirm that this is correct.
You'll want to grab the front two corners first. Carefully and firmly pull down. Once those are free do the same in the rear corners.
