We have the Outlaw Inductions on sale for $219.99 until Sunday, August 30th -
The GM Outlaw Power cold air intake system will be the first and last intake system you will ever need install onto your vehicle. Installation is fast and easy out of the box. You do not have to hassle with small gaskets and screws and installation does not require more than 1 pair of hands like some of the other intake systems. We have reduced the amount of restrictions and turbulence in this intake system to deliver you cold non turbulent air at the highest mass velocity possible.
The Outlaw Power airbox has a large opening that seals against the inner fender. Seal trim is provided and attached to the airbox. The sealed system ensures cold air is ducted into the air box. The enclosed air box shields the air-intake charge and air filter from trail dust, road grime, and torque-robbing heat. This provides complete protection for high-torque engine demands.
As cold outside air enters the airbox, it is efficiently directed into the Outlaw Power air filter. Outlaw Power uses a contoured air filter top, as opposed to a flat filter top. This design was created to increase airflow and reduce air turbulence, which increases air transfer efficiency.
Once inside the filter, an inverted velocity stack design guides the air as it enters the filter and directs the air toward the intake tube. The air is then accelerated through the main velocity stack into the mass airflow sensor and intake tube.
In addition, this utility patent-pending design allows for greater filter area within the contained air intake system because the connection to the intake tube is made on the exterior of the air box, rather than on the interior. Greater filter area results in increased filtration capacity, which allows for highest airflow and performance.
INSM-0010 1999-'06 Outlaw Induction for 5.3 and 6.0 powered GM Full Size GM Trucks and SUVs $219.99
INSM-0032 2007+ Outlaw Induction -Cadillac/ Chevrolet/ GMC, Avalanche/ Escalade/ Sierra/ Silverado/ Suburban/ Tahoe/ Yukon, 5.3L/ 6.0L/ 6.2L $219.99
Orders can be placed online or by giving us a call at 1-877-482-9763.
Have a great day!
2004 Cadillac Escalade
is this something that anyone can undertake? in other words.. if this is the first time i'm doing anything under the hood, is it that easy?
