What is the procedure for opening a CTS coup door if the battery is dead(without using a tire iron)?
Had this issue a few months ago on my 2014 - there is a key in the key fob, you just have to press a button and pull it out. You can then get into the driver’s side which has a physical key slot.What is the procedure for opening a CTS coup door if the battery is dead(without using a tire iron)?
