When my OnStar went down at the beginning of this year due to the FCC discontinuing analog cellular service, I decided it would be a good idea to use the buttons and microphone already installed in my 2001 DTS to interface to an existing bluetooth hands free kit.
It took a little longer than expected, but its now complete.
It works great and is real easy to install. You just locate and remove the OnStar VIU and plug this module in its place. Using the buttons on the mirror, you can place calls, accept calls, transfer calls and even mute calls. The module will automaticaly mute the radio when a call comes in. Even the steering wheel volume controls work to raise or lower the volume. The voice quality is excellent since you use the high quality OnStar microphone. And best of all, there are no wires to run. The OnStar LED indicates call progress, pairing, mute status, etc.
This module works only with older cars utilizing the class 2 communication bus. It is intended to replace the obsolete analog onStar system that is no longer in service with the bluetooth unit which ties directly to your cell phone. When installed, it mimics the OnStar communications so that no codes are set.
Is this something you guys might be interested in? I am not an authorized vendor, and I do NOT have anything to sell yet, but with enough interest, I could set something up.
