after seeing the squires turbo system (the turbos are in the rear of the car) and having removed the exaust to replace the rear subframe i noticed all that space where the final mufflers reside. it got me wondering how the n* can handle boost. i am only dreaming around here but.............with all the talk of this engine needing to "stretch its legs" i thought it may well be able to handle it. how strong is the bottom end on a stock 4.6 ? just a thought.......dont flame me for thinking a little:stirpot:
You might check with some tuners about the project. I was advised the 10.5:1 compression prevents any forced induction.
SRX
Absolutely! You need compression down around 8 - 8.5
2005 SRX N*V8 RWD; 1999 DeVille Concours
Suggest looking at the XLR-V engine specs; seems that it is 4.2L N*; it is also a different block (ie, sand cast vs standard N* block) with bore reduced to provide more head gasket surface due to compression of blown intake and different oil galleries.
My late father tried over many years and many different engines ( prior to mid 1980s and no N*s) to add blowers; result was always the same: short term high performance, but lower ends always go in quick time. Just maybe the engine designers are smarter that we think.
We have turboed many cars with compression in the 10's and currently do a kit for the GM V6 3.6 used in the CTS, which has a compression ratio of 10.2:1 in the version sold in Australia
