Hello,
I have a 2008 CTS.
The steering wheel started to shake when you would hit speed of 45-60 and front wheels would overheat. We replaced the disc and brakes. The shaking stop but the over heating continued. We then change the caliper on the driver side as that is the wheel that would heat the most. After we make change it, we ran into the issue of when you started the car, the brakes would engage and stay stuck. We changed the brake line and made sure no air was stuck. Everything seems fine but when you drive you feel a bit of drag or lack of power, and driver side starts to heat up. Anyone have any idea on why front tires mostly driver side heats up , currently no lights and no error codes showing up on the dash. We are seeing if the brake master cylinder needs to be replaced or oil pressure line need to be change , and the Guage isn't working.
Any ideas or suggestions would be helpful
I have a 2008 CTS.
