1 - 1 of 1 Posts
escalade ext
OK was driving today and went through a tunnel had the drl's on then they went to night time mode everything went black!!:mad: no instrument lights not even the information center worked??? got out of the tunnel when the drl's came back on everything worked??? I'm so stumped I checked all the fuses under the hood in the box on the left also check the fuses in the truck on the driver side dash all seam good?? so far the symptoms are drl's on the lights work except for the instrument cluster this happens weather the headlights are turned on auto or manual when i disabled the drl mode the info center goes blank no anything also no fog lights no matter what mode even with the lights in manual seam to be getting power to the switch though? any ideas?? please help me:worship: is it possible this is a relay problem??
haven't noticed anything else
1 - 1 of 1 Posts
