What, exactly does this mod do for you? I can't see the benefit. The "improved driving" of letting out the clutch/no clunks" etc...didn't that come from the diff bushings?
The mod made for this car lost the flex coupling, and lost the hanger bearing and rzeppa head assembly...
Overall between the factory shaft and the shaft i used in the car it is probably around the same weight as the original.
I could lighten the stl shaft up some more and make it come in a few pounds lighter.
The AL shaft or Cf shaft would be lighter, but there both going to be very tight in the tunnel and need to shave the tunnel at the hanger bearing structure points. (Cf is 3.750 diam / AL 4" diam)
I did another caddy the other day and im looking into yet another way to get around the front tripod set up a totally different way....
Now the other issue is cost....
What i did for the caddy the other day was a huge diff in cost to the caddy replacement, and if he should later on upgrade to the single pc shaft he just needs the front fix i go with which will save him money since the rear section can be used on the new shaft...
Pretty much the benefits are cost, and there is some performance benefit since you lose the flex disc.
Just be a little questioning of what someone does..... For the length the shaft has to span in 1 pc and what the car is capable of a single piece less then 3.5" diameter is pushing safety...
A 3" single pc shaft in stl i wouldn't do....
