Once we get our new cnc machines up and going we'll be making shafts, they will be a little different then this one though.
How long was this driveshaft? We have 3.5" aluminum driveshafts in GTO that are 50+ inches that handle 700-800 hp no problem.
Chris
GTO is totally different..... The GTO can use a different slip yoke, the Caddy can not as it does not share the exact same trans.
The caddy needs a slip sleeve style AL shaft, which is a few hundred more right there.
The CF shaft is the same issue and would start at 3.750 outside diam...
The shaft in this car is 3.5"
Becareful when doing these mods, because as i seen 1st hand at some other shops expertise of squeezing a hanger in there and making me chase a vibration and wasted time until i thoroughly looked at what the other driveline shop did....problems solved....
As for the wanting to do 150 mph.... it is not the speed of the car that is the issue it is the speed of the shaft at 150 that is the issue...
So if you know what rpm you are at and at 150 mph in 1 to 1 then i can tell you what you need for that speed...
Safely the AL 3.5" shaft will spin faster then stl, 4" AL would be the end all to any hp/rpm issue, but the room restraints in the tunnel and a need for solid or atleast nylon bushings at the rear diff would most definitely be required.
As of now i have another caddy and i have come across broken case diff mounts at the upper pin location.
Has anyone else suffered this issue, i already have the fix for this car without him needing to buy a new diff housing.
Has anyone else that is racing there Caddy noticed or had the same issue with the front mount bushing of the diff housing ? ? ?
