Looking at a 95 Eldorado with fairly low miles and I am having a hard time finding info on this head bolt re-torque issue.
What exactly was the issue and was there really a maintanence requirement to retorque the head bolts at 25K miles?
What about after 25K miles?
Can someone fill me in on actual procedure?
White Diamond 2001 STS
If the car has less than 25k miles, and you're looking to try to re-torque the cylinder heads, I wouldn't touch it. If they've lasted this long, they'll likely last as long as you ever own it (seriously). Trying to re-torque head bolts on a 12 year old installation is asking for trouble.
Edit: I should say, the required maintenance would be draining the coolant and refilling (no need for Dexcool in your application, just regular green coolant) and adding a package of the cooling system sealing supplement tabs.
No, the car has around 50K on it.
I am trying to determine if the bolts should have been retorqued at 25K. Someone said there was actually a place in the owners manual that said it was required. True?
No it is not required nor recommended. Head bolts have a thread locker on them like Loctite. Retorquing will break that bond. Don't touch them.
'93 STS (sold), now looking for a CTS Wagon soon!!
Those cooling system tablets..... How long are they effective?
Well, I recall the Guru saying that after many years the fibers get chopped up by the water pump impellers and become less effective. I would have to guess that that it is longer than the coolant change interval.
