94 sedan deville
hi here,, 94 deville rear susp. sounds like a bad mattress wonder what exactlly it could be... anyone with this same prob...
:cookoo:
2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
I will assume that you are squeeking. Check any moving part that has a rubber busing. Sway bar, control arm, etc. When you think you have found the culprit, spray the hell out of it with WD-40. Try and get it between the rubber and steel. Test drive and see if the noise is lessened. If it is, you found the squeeker, and you can replace the bushing. If the squeeking doesn't stop, go to the next bushing, and do the same thing.
Don
