So what if I only have 300 miles; I stopped by http://www.eastcoastsupercharging.com today to drop off my friend's Z06 and I think I'll be stuffing around 7k+ into the car for:
what he described as a 'mild' head/cam job - $6500
hurst short throw kit - $250
once we can make it fit, some kind of filter - $TBD
computer (kill CAGS, fix airflow, etc) - $TBD
dyno tune / measurement - $125
suspension (rear, at least) to cure wheel hop - priceless (!)
4 new tires (Michelin Pilots perhaps)
I'd like to go blackwing but there is simply no room I'm thinking. May end up with something like the K&N that MorePerformance has.
This guy does all Vette/LS6 work (he wouldn't touch the CTS-V otherwise) and he says that it should pull around 400 at the wheels after the head/cam and the rest will obviously have to be discovered as we go. Don't think there is room for a charger on it, though at $8k installed it sure is tempting.
Thoughts? Comments?
Notes:
He suggested doing this to break it in, this may be redundant for some of you but to be honest it's my first heavy duty sportscar, so be gentle.
change oil at 2-300 mi (3-400 worst case)
use a basic 10W-30
at 500 mi change again and go with synthetic from that point forth
I will have dyno results when I hit 500 miles or so, will post to let people know some before/afters for those of you considering cracking things open a little (or a lot).
- Cal
edit: head not headER...sorry
Thoughts? Comments?
Notes:
use a basic 10W-30
- Cal
