Hey folks,
a question to the petrol... uhm oil-heads of you
I have advised an company to do an eninge oil analysis for my 2.0T ATS, I use LiquiMoly Special Tec DX 1 5W30 (Dexos 1 Gen 2) and they have measured that the viscosity of the oil is lower than the minimum limit value. The oil was driven for about 3.100 miles in 8 months.
A 5W30 is supposed to be within 9.3 - 12.5 mm²/s at 100 °C (or 212 °F).
My 5W30 engine oil just hits 7.69 mm²/s at 100 °C (or 212 °F) - and 36.81 mm²/s at 40 °C (or 104 °F).
The viscosity index is at 185.
They have stated it's caused by a slightly increased fuel entry to the engine oil due to cold starting / short distance driving / technical error. In my case it should be short distance driving (I hope so) and the oil doesn't reach optimal temperature from time to time.
So others recommend to go for a 0W40 or 5W40 (thicker base oil) instead of 5W30 to avoid less viscosity caused by fuel entry.
But with the same requirements:
API SP or API SN+
ACEA C3
But these 0W40 / 5W40 won't match the Dexos 1 Gen 2 approval.
What are your thoughts? 🇺🇲
API SP or API SN+
ACEA C3
