Ranger said:
Yep, either of the sites Ranger mentioned. Someone told us once that the oil level sensor could be changed with the oil pan full. Later, someone else came along and said "I did that and made a huge mess." I had to replace mine a few months ago. I would suggest doing it when you change the oil. It's very easy to change it. Just need a wrench and the new part. Let us know how it works out for you.
2010 DTS
Considering that the CHECK OIL LEVEL message doesn't come on til 2 qts. low, I would have to assume that the sensor is 2 qts. below the full line. I would definately not attempt it with a full sump. I would follow Micheals advice and do it at oil change time.
