1 - 10 of 10 Posts
That is the display that I keep getting on my car at certain times of the day, more specifically when I cut the wheel for parking, turning, etc. the oil light pops on when that happens as well. Someone please tell me the solutions and how urgent this really is. Thanks
· Master of the Dark Art of Diagnostics
99.99% of the time the problem is a failed/leaking oil pressure switch -
cross your fingers and replace the switch -
you should update your information -
if I knew the year and model of your car -
I would have included the correct part number -
and the best price available -
· Administrator
Please use the Profile and Settings tabs to update your profile to show proper vehicle information and maybe approximate location. It sure helps with diagnosis and advice.
Look at most members' username banners ................
IF the car has a Northstar engine the most likely culprit is the oil pressure sending switch, as posted. Replace it with an AC Delco unit - RockAuto.
Click a thumbnail to enlarge, use your browser <-- to back out.
1996 Cadillac Deville
Agreed that the very likely culprit is the oil pressure switch. Just like in soo many other GM vehicles...
And what a pain to change unless you have small hands with long fingers. Or you remove the oil filter housing. I didn't and it was a PITA, but manageable.
ABSOLUTELY!!!
1 - 10 of 10 Posts
