The OLM (no matter which brand/model of vehicle) is scary accurate in advising on remaining oil life - with a significant "safety" margin built-in. The systems use a slew of inputs and algorithms to determine what conditions the vehicle operates under. Slow, cold, short hops = low oil life. Long steady highway runs = max oil life. Some systems even use turbidity (how "dirty" does the oil look) sensors to factor in that variable.
You reset the system at oil/filter change. It then monitors stuff like ambient temp, coolant temp, power level, rpm, braking, intake airflow, fuel consumption, yada, yada, yada. All that is mixed together to calculate how fast the oil is "wearing out". I'll guess that brand new vehicles have a "break-in" factor in there, too - sort of like the rpm limiters in some vehicles for the first 500 miles. OLM has come a long way since the 80s.
Let's assume your particular vehicle was designed, built, and tested using Mobil 1 synthetic 5W-30 and a GM branded oil filter. THAT's what the system algorithm in THAT vehicle is groomed for. BUT, since all "modern" 5W-30 synthetic or blend oils are so damned close in formulation and characteristics - no matter who markets them - the system will still accurately advise on life remaining no matter what you use. Part of that is why there's a significant safety "fudge factor" built in.
"But, Sub, Slippery 70 5W-35 Magic Blend synthetic is a MUCH better oil than Mobil 1 (my friend says so) - how does the OLM know it's so good?" Your choice, your call, your money. Just as with gasolines, spark plugs, tires, oil filters, car wax - we all have opinions and no one can change them. "My mind is made up - please don't confuse me with facts!"
