can someone please help where is the low level oil sensor located i been looking all over the oil pan can not see it i have the low oil level sensor light on....not low oil pressure..i can not find this sensor...2007 escalade base
xTooltipElement
Service Information
2007 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 1698846
Engine Oil Level Sensor and/or Switch Replacement
Removal Procedure
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Place a suitable drain pan under the oil pan drain plug.
Remove the oil pan drain plug (430).
Allow the oil pan to drain completely.
Re-install the oil pan drain plug until snug.
Remove the drain pan from under the vehicle.
Disconnect the engine harness electrical connector (4) from the oil level sensor.
Remove the oil level sensor from the oil pan.
Installation Procedure
Notice: Refer to Fastener Notice in the Preface section.
Install the oil level sensor to the oil pan.
Tighten
Tighten the sensor to 20 N·m (15 lb ft).
Connect the engine harness electrical connector (4) to the oil level sensor.
Ensure that the oil pan drain plug is tight.
Tighten
Tighten the drain plug to 25 N·m (18 lb ft).
Lower the vehicle.
Fill the engine with NEW engine oil. Refer to Fluid and Lubricant Recommendations and Approximate Fluid Capacities .
Start the engine and inspect for leaks.
© 2011 General Motors Corporation. All rights reserved.
This is the low oil level sensor on the 6.2L:
Did u ever find the oil level sensor I sure can’t find it on my Escaladecan someone please help where is the low level oil sensor located i been looking all over the oil pan can not see it i have the low oil level sensor light on....not low oil pressure..i can not find this sensor...2007 escalade base
The 2007 Escalade did come equipped with the oil level sensor, here is the part number 12603782. This video may help. Escalade ENGINE OIL LOW ADD OIL FIX - YouTubeDid u ever find the oil level sensor I sure can’t find it on my Escalade
Moderator edit: The member whom you just quoted has not logged in for over 5 years, After about 2004 or so many models came without an oil level sensor - it's back to the tried and true dipstick check every week. Sub.
You’re welcome. This might helpCameron thank u so much for your help but my Escalade has the drain hole but there is no oil level sensor next to that anywhere in that side an I was just wondering if is any were else thank u
