1 - 2 of 2 Posts
I have a 95 STS with 215,000 mi. I've got oil leaking somewhere but I'm not skilled enuf to figgure out from where. However, it does "appear" that the oil level sensor at the front of the oil pan may be leaking. I'm willing to spend the $40 dollars or so to replace it because 1) it looks easy and 2) would eliminate at least that....
My question is.... how likely is that the cause? In other words, has anyone else found their sensor to be leaking? Or is it worth just giving it a shot... Thanks for helping!
The oil pressure switch is a more likely culprit. It's located on the oil filter adapter.
1 - 2 of 2 Posts
