If you change your oil yourself (and you know you put in six quarts at the oil change) then it appears it is burning one quart per approximately 3,000 miles. Although not desirable, this is going to be considered normal, so unless it gets worse, you'll not get any relief from the factory.
Now, just asking here; do you check your oil regularly, do you check it the same way all the time (ie similar oil temperature, same approximate time after engine shut-off, etc.), do you have a flat surface that the car sets when checking?
It seems as the simple oil check has gotten more complicated in the last couple years (as opposed to the olden days); see the CTS forum thread if you haven't already done so, pages of comments on checking the oil. It just shouldn't be that hard.
