1 - 10 of 10 Posts
2007 CTS-V, 2001 Honda Shadow Sabre
I have an 03 CTS with the 3.2L motor. While it was at the shop today getting the rearend oil changed (differential whine), I noticed oil on the underside near the front of the engine. Investigating further I popped the hood and found oil all over the intake tubes going down in front of the engine. I pulled off the tubes and found more oil on the inside on both sides, and inside the intake manifold.
Has anyone else experienced this or have any idea what might be causing it? Thanks!
Discussion Starter · #4 ·
Ok, I'll give this a shot.
the screws on your heads might be loose and causing this. tighten them up (a few people have done this) and this should solve your problem
I had the same probleme a month ago, tightend the screws and probleme was solved for me.
So what "screws" are you talking about? My car is at the dealership right now for an oil change, replacement of the left rear hub bearing (i thought it was the diff, hence why i was changing the diff fluid last week), and replacement of the evap vent valve (causing CEL and difficulty starting after fueling). They tried to find where the oil in the intake is comming from but said they cant figure it out. When I mentioned tightening the "screws on the heads" they werent sure what I was talking about. Thanks!
2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
haha...this is your cadillac dealership that doesnt know what you mean by tightening the screws on your heads? you better go pick up your car ASAP if they dont know what you mean, cause they obviously only have your car in there to take your money. we are talking about the screws/bolts that hold the heads on...
What size torques socket was the valve cover bolts? I don't feel like buying a whole set I have a couple but not the right ones.
06 CTS-V
8mm normal socket will work, can't remember what that converts to in torx. don't over tighted you'll snap the bolts. throw some lock-tite blue on them if you have them out. to get all the bolts out you'll have to remove your intake manifold.
If your head bolts are loose you'll probably have bigger problems (they would be lock-tighted)
1 - 10 of 10 Posts
