Hey guys, I'm having a problem finding the pcv line that connects the intake to the manifold. I want to keep those nasty oil particles out of my intake, but I can't find what I'm looking for. Does anyone have an idea where that line into the intake manifold is?
2014 XTS Premium
If you haven’t figured it out, here is a photo.
I had the same trouble as you. First I thought it was #2 in the photo, but when I hooked it up, there wasn’t enough vacuum pull. Looking further, I found the correct one on the backside of the motor. See second photo for an idea where it is.
Red line runs from the PVC to Can Inlet.
Blue line runs from the Can Outlet to Intake Manifold.
Its working fine. The can is notably full when I check in between oil changes. I’m at 89,000 with no symptoms of carbon.
Finding a place to install the can was a treat. Curious what you come up with. Please post.
I should have added I have the twin turbo engine. I did, however, run both my turbo vacuum lines into a can as well as my primary pcv to a can. The twin turbo can doesn't collect a lot of oil due to minimal boost time. The primary line has collected easily 4 to 6 Oz of junk and I'm not even finished with 1 oil change
2014 XTS Premium
Glad you got it figured out.
The stuff in your can looks exactly like what I pull from mine.
In fact, this post prompted me to check mine and it was nearly full.
thanks for the reminder!
