OEM Ignition coils AC Delco or Bosch????
1 reading
8.3K views 11 replies 5 participants last post by  DFWSRX
I need to replace a Coil I have a misfire code cyl 2 anybody know what OEM brand the ignition coil is???
What brands did you guys use for replacement coils?
#4 ·
Some brands are reboxed acdelco.
I chose those. Get them from amazon for a better price.
As prices change they've gone up $10 since I ordered.
ACDelco D598A GM Original Equipment Ignition Coil
https://www.amazon.com/dp/B0010GEBKI
Even the 3rd party knockoffs are nearly $100 locally.
And most stores around here don't carry them in any version.
Last time I tried local it meant going to 4 stores to get 3 coils and paid excessively to do it.
#6 ·
Of course I will be ordering from www.rockauto.com with discount code included :)
Choices are
BOSCH 0221604112 {#00147} .............$37.79
Actual OE part;
ACDELCO D501C {#12613057, 12629037} GM Original Equipment ..........$57.79
Leaning towards Bosch just because its $20 cheaper and I think I should be fine with it.
#7 ·
I put a set of Delphi's in my 2006 STS. They were $45 a piece from Summit.
Summit has free shipping on orders of $99 or more.
I've read too many horror stories of late about Rock Auto. Back in November 2017, you can no longer talk to a live person. All contact is done by chat and/or email.
I've also read numerous complaints, that if they mess up your order, they make you pay the shipping back.
#9 ·
Ordered
Actual OE part
and a new AC Delco double platinum plug also added Fel-Pro upper intake gaskets.
Plan to do it all this weekend hopefully get rid of my cyl 2 misfire.
#12 · (Edited)
Yep that's definitely a misfire code get the code read (AutoZone for free) so you know what cylinder is the problem child.
I can now confirm the OEM coils are indeed Bosch so I was happy I ended up going with Bosch.
The job was easy as hell 30-45 min max didn't even fully remove intake....just loosend bolts and pryed it up.
I also suggest Iridium spark plugs I put in double platinum's but recently found out we should be using Iridium
