2010 SRX 2.8T
I'm looking at a 2010 SRX 2.8T from a Canadian GM dealer CPO'd with 60k on it fully loaded!
It is a US vehicle imported to Canada.
Just wondering if the odometer is in Kms or miles?
I see the speedo is in MPH and I'm not sure if you can switch the presentation to KM/Hr electronically ?
I have a Mercedes and I can switch between the two, and no it only displays one or the other not both at the same time.
I also see some fogging in the headlights?
Also what does a certified pre owned from GM give me?
2014 S550, 2018 XT5 Platinum, 2019 XT4 Sport :)
Have them print out a service history on the car.... R E D R U M R E D R U M :canttalk: I'd skip that one..... My 2010 clean as a whistle from Florida... Never seen salt roads... Clean all around. Been in for service well over 6 times in six months.... Coil failure, OnStar antenna failure, Radio failure, Strut failure, Drive shaft service, Brake / gas pedal Adjustment failure, front axle seal's leaking, HVAC control module ( air adjustment ) failure. All under CPO thank goodness!!!!
