1 - 9 of 9 Posts
2003 CTS
Hi CTS forum!
I have had these codes popping up intermittently the last few days. I pulled them with the onboard scanner.
P0161--- bank 2 sensor 2 heater low voltage
P0157--- bank 2 sensor 2 low voltage
P0158--- bank 2 sensor 1 high voltage
P0153--- bank 2 sensor 1 slow response
P2099--- bank 2 post cat fuel trim too rich
I don't think it's very likely that 2 O2 sensors would fail at the same time so I suspect that the ECM or another component is to blame.
Do y'all have any ideas on what this issue could be?
2003 CTS 1SC Luxury Sport
When you have a rich code accompanying the 2 related sensors on the same bank, I would say that sensors fouled. Fix your rich code and replace the sensors. Doesn't sound like an ECM.
2003 CTS
the O2 sensors are pretty easy to change. you may need a can of PB blaster, WD40 or something of the sort to break them loose. post cats can be reached with the car on a set of ramps. bank 2 is drivers side. I got mine from amazon or rockauto.com, pretty reasonable if I remember correctly. do a search in this forum for O2 sensors, I am sure there have been some write ups, or check the DIY at the top of the page
2003 CTS
Discussion Starter · #4 ·
Thanks for your replies guys! jran, how would you test to see if the engine is running rich? And what could cause that? Maybe a bad injector?
Only way to test and see if it's running rich is to get a scan tool and watch your long term fuel trim. Negative is rich and positive is lean. Ideally you want 0%, but + or - 5% is realistic and still within perimeters. Lots of things can cause an engine to run rich, O2 sensors being one of them. Bad set of spark plugs, a leaking injector or fuel pressure regulator, the list can go on.
2003 CTS
Discussion Starter · #9 ·
josney, It cost $900 at the stealership. I know I could have done it for a lot cheaper if I bought one online and found a shop with a Tech 2 to program the VIN, but my parents wanted a warranty on the work.
Corvanti, I hope the new ECM fixes your problem. I'll keep an eye on your thread.
1 - 9 of 9 Posts
