I have a 2003 DTS. Over the past year and a half I have had to replace or have replaced the firewall side ignition cassette, intake manifold plenum gasket, and the cat. So I guess its no surprise that check engine light now reports: P0151.OBD 2 says this is bank 2 sensor 1 low voltage. Can anyone tell me which sensor this is. Thanks
Bank 2 is the front (left) bank. Cylinders 2,4,6,8
Bank 1 is the rear (right) bank. Cylinders 1,3,5,7.
Depending on the year model, O2 sensors:
B2S1 is the left exhaust manifold sensor
B1S1 is the right exhaust manifold sensor
B1S2 is a pre-cat sensor
B1S3 is an after-cat sensor (BUT if there is no pre-cat, then this becomes B1S2)
Discussion Starter · #4 ·
Thank you gentleman, I'll get under and take a look. If I remember, you had to remove something to gain access to the front exhaust manifold on my 97 DeVille.
