Hi All,
I wrote last week about an apparent overheating problem. After replacing both radiator hoses, thermostat gasket, water pump gasket and finally the radiator, the problem persists. Having fixed all of these minor leaks the system was pressurized and it was discovered that I have a leaking head gasket presumably due to the head bolts working loose in the block. The radiator was partially plugged, I believe, with stop leak that the previous owner placed in the cooling system in an effort to plug up the head leak. I'm told this is an approximately $4000 repair. Currently, the hydrocarbon reading in the coolant is 42.
Is there any remedy short of taking the engine apart and putting steel inserts into the block, etc?
