61 - 80 of 100 Posts
2000 DTS 194,000 miles, 2000 DHS 203,000 miles
RippyPartsDept said:
how did you do that?
'99 uses coils and wires for ignition and 2000 uses the coil-on-plug design
:hmm:
If that's the case then his 99 special or different. Cuz it's for sure a 99 DHS, has 99 front struts (the sway bar links connect to the strut, not the control arm). And his engine and harness was identical my 2000 DTS. When my mother still owned my DTS we put a scrapyard engine it. That engine leaked oil like crazy. so the scrapyard sent us another and didn't want he first one back. I re-sealed it and put it in my service writers DHS. After 2 years, the scrapyard engine blew thread gaskets. My parents asked if I wanted the car, I took it and fixed it all up. So anyways his 99 DHS is identical under the hood as my 2000. I not know the month it was made, perhaps it's close to the change over to 2000 and has a 2000 drive train.
05 STS4
Dhs wasn't started until 2000. 1999 was the deville, delegance and concours and fleetwood extended body. 2000 was the Deville, dhs, dts, des.
I smell something fishy...
Bottom line: 1999 flat tappet engine is VERY different from a 2000 and later roller cam engine - mechanically, ALL ignition, PCM, electrical harnesses and sensor-wise.
Every since he bought the car he's told me it was a 99. I've never looked for myself. He told me he couldn't find the quick struts for it, cuz they don't make them for a 99. But I know for a fact that everything under the hood is identical to my 2000. But I bet ya first thing Monday morning I'm gonna look and see for myself lol.
Check out the build date on the driver's door sticker - Model year 2000 production began in ~August 1999 and ran into late June 2000.
You could enter the sample subscription page in www.compnine.com and plug in the car's VIN to see what it is, too.
Here's the VIN breakdown for the Seville series ............. Deville bodies would have different characters in the 4 and 5 locations.
1998 Cadillac Deville
:hmm:
That's funny bc I've seen a few guys in the junk yard pulling out 2000+ Northstars to put in 98's/99's Deville's
I use to laugh to myself bc from what I've read they won't even fit/connect the same
Maybe they have some secret method??????
Sent from AutoGuide.com Free App
Too bad that almost no one can put 2 and 2 together and come up with 4............ as in the new ads for the "2014" cars - many on sale next month ??????? DUH !!!!!
........... and there's a pretty good chance, particularly with offshore cars, that as of some date - say 07-01-13 - EVERY one of their cars, regardless of when it was actually built, will be a "2014" model. (Remember: We have European members who own and drive "2001" Sevilles - built in 1998 and early 1999 - a VERY different car from the 2000 and later model years.)
Our American lines generally shut down about now, undergo reconfiguration, and start patching together the "2014 Flapfish Xt3bR14GT" in early August.
97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
Discussion Starter #72 (Edited)
A note on the 04+ transverse Northstars, you cannot use the oil manifold plate that fits the 1995/96-2003 Northstars. The oil dipstick tube will not fit properly. If you're doing a build or a re-seal on a 2004+, you must use the updated oil manifold plate.
Likewise, 93,94,part of 1995 I do believe, used one type of manifold plate- without the integrated rubber seal for the oil pump pick-up tube. These pick-up tubes were sealed to the oil manifold plate with an O-Ring. I will get part numbers and post to my website yet.
westman, Your posts on a replacement engine for your DTS have been moved to your own thread in the main Forum.
What about the 4T80E transmissions? Are they all interchangeable with these engines? Will a 1994 transmission work on any 1995-1999 caddy?
Or, will a 2000 and later 4T80E work in an earlier 1996 Deville Concourse car?
I would think they would all be the same except for final drive ratios.
Anyone have experience with this?
2006 xlr engine +trans
Any information on oil pan interchangeability would be greatly appreciated. I have a 2006 XLR 4.6l VVT Rwd engine that I need a rear sump pan for a swap into a 61' chevy. My research thus far seems to point to no different oil pans out there that would bolt on to this engine, but then I found this thread and thought I would pose that question to the experts on this thread. If what I have dug up is correct (no other pans fit this block, no aftermarket options), then I will continue looking for a GREAT welder who can reshape the factory cast aluminum pan, and fab up a relocated oil pickup. If anyone has a resource for me though to avoid that route, I would be forever indebted to them! Thanks in advance for any replies.
A Northstar pan is a Northstar pan, and they changed from time to time over the engine run. BUT no other pan on earth will bolt on and a Northstar pan will fit no other engine on earth.
A Northstar cylinder block, halfcase and oil pan torque together to form one machined single unit.
A '61 Chevy is quite a heavy car for a low torque Northstar. The Northstar has to wind up to make power - a good ol' 348 or 409 would be a MUCH better choice - and the availability of "speed parts" for a Northstar is slim and none.
