Howdy. This may be my first post, but won't be my last. Not new to message boards or cars...
My name is Philip. I'm in mid-Michigan. I'm 18.
My dad and I share our hobby of Buick Reattas. Based on the E body platform and built from 1988-1991 here in Lansing. The only power plant was the first 3800, though 1991 got the Tuned Port Injection (TPI with my buddy Mario) 3800.
Reattas are great cars. I have an '89 coupe, my dad has a '90 convertible, and we also have another '90 vert which we're selling. I've got over 1000 posts at the Reatta.net board. The bad thing about Reattas is that they're not as fast as they should be. The 3800 puts out a mere 165 horsepower, which isn't much for a 3500+ pound personal luxury car.
We want to use a '90-91 (which have a more conventional dash/computer system and NOT the ECC touchscreen/CRT system) and a 90s Northstar-powered Cadillac and put the North in the Reatta.
I understand that I would need to swap the entire motor, transmission, computer systems, and wiring. I don't think it will be too challanging because I figured that because the Allante was on the same platform and had the North in '93, there's enough room in the Reatta's engine compartment. The best way I think to do it would be to buy a salvage (rear ended, rolled over, etc) Caddy for like $1k. I would know how everything is situated and would certainly be cheaper than getting it all from a salvage yard.
The only significant problem I can think of is the instrument panel. The Reatta uses a vacuum flourescent (digital) panel. I can assume that there's no compatibility between them. Does the Northstar use an ECM and a separate BCM? Reattas do, and the only reason I cna think of having to keep the existing BCM would be for climate control. I'd keep ODB/2 of the North. I'd probably get some error codes because of the climate control not really being present but from what I understand, it can be reprogrammed to ignore them.
I might be better off to use the Caddy instrument panel instead of the Reatta panel.
I don't know. What do you guys think? They've been put in Fieros before. Think of a Reatta is just a bigger, luxury Fiero
I thank you much.
