1 - 8 of 8 Posts
1997 code Y motor.
At the end of the intake manifold next to the power steering pump (opposite end from the throttle body), is a large flapper thingy that opens directly into the intake. It's spring loaded closed. What is it, and what's its purpose? Looks like a toilet tank flapper valve.
'98 STS (RIP @ 206,xxx miles)
That is a relief valve to prevent positive pressure damage to the non-metallic manifold as in the case of a "backfire".
Cadillac Technician
none
It's called a "backfire valve" it pops open in the event of a backfire so the intake doesn't explode.
Guess how they figured out that it needed to be there?
:D
1996 Eldorado Sport Coupe, 2009 Black Navigator
They figured out that it might be easier to give out burp instead of giving out a stinkie FART?
Cadillac Technician
none
We also had problems on some 3800's back in the 90's with exploding intakes. They issued a software update for the PCM to fix that concern though.
Not sure if I can find any pictures but I have seen some.
2010 DTS
I remember hearing about that when I did some research prior to replacing the intake on my wifes '96 Bonnevile (not for that reason).
Banned
2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
exploding intakes are fun especally when you do a wet nos system and it pools in the intake then KABOOMY!!!!!!!
1 - 8 of 8 Posts
