1 - 16 of 16 Posts
2001 eldorado,2008 DTS,2005 XLR, ','95 eldo,' ,'11CTS-V,'66 corvair.'03 deville,'00 deville
1997 code Y motor.
At the end of the intake manifold, next to the power steering pump (opposite end from the throttle body), is a large flapper device that opens directly into the inside of the manifold. It's spring loaded closed. Looks like the flapper in a toilet tank. What is this, and what purpose does it serve?
It is for relieving pressure from the intake manifold in case of overpressurization.
94 Fleetwood Brougham
Provisions for Supercharging??
Cadillac Technician
none
This looks familiar... I'll say it again just in case anyone missed it.
It's called a "backfire valve".
When the engine backfires the pressure has to have somewhere to go.
This valve lets the expanding gasses escape rather than exploding your intake.
Ok, you are likely right, but I have to ask. GM went to the effort to design this in. Is backfiring REALLY a problem on a modern computer controlled V8 engine??
2010 DTS
Not often but it is possible and when it occures there better be away to relieve pressure or your manifold may become a grenade.
Cadillac Technician
none
Back when the Northstar was in it's infancy it really was common.
It really doesn't sound like a backfire anymore when it happens.
Just a big "poof" sound. If it wasn't for the valve it would be a loud explosion followed by a shower of small black plastic pieces.
It's been redesigned a couple of times, now it's more of a springloaded plunger. Usually you'll hear this in action when you crank it for a short period and let go of the key but it doesn't start, at the last instant it will go "poof"!
That's the valve in action!
I have seen it posted here before. It does happen apparently.
I've got the flapper, and I had a backfiring problem caused by a leaking injector. Let me tell you - it's not a "poof" sound. It's a gunshot. Anyone in the vicinity will turn around to see whether they have to run. It was fun. :rolleyes:
White Diamond 2001 STS
As engines have gotten more sophisticated, backfires certainly aren't a "normal" occurance, but they can still occur. Recall also that the Northstar's intake manifold is a composite (plastic), unlike steel or aluminum that you'd traditionally find. Plastic is a good choice for many metrics, but backfiring resistance isn't one of them...so they included a valve for the engine to relieve itself in the event of overpressurization...so you don't ruin your expensive intake manifold.
Cadillac Technician
none
Not sure about prices, but replacing a N* intake is not really that hard.
How long it takes depends on what kind of tools you have and what kind of skills you got.
The LSx engines use a similar composite intake, and prices in the aftermarket for performance versions are in the thousands of dollars. If you needed to, I'm sure you could find a used intake manifold from a salvage yard for not much money. It'd probably be awfully expensive to replace with a new GM part. Physically, it's easy to replace. No draining of coolant -- it's a dry manfiold. Thank you GM!
The lSX intake is performance intake for the LS1.Normally the intake for the LS1 is around 200 from GM! I would say a Cadillac Northstar is around 200 also for the Northstar! I will check today.
When I said "LSx", I meant the LS series of engines, like LS1, LS2, LS6, LS7. There are performance intakes for those. Here are a few examples of aluminum LSx intake manifolds:
http://www.lmperformance.com/1897/1.html
http://www.prostreetonline.com/buy/weiand_intake_manifolds/
The LSx intake from FAST you speak of goes for almost $1000:
http://www.powerandperformancenews....n=PROD&Store_Code=FS&Product_Code=LSXmanifold
It would be interesting to know how much these intakes are, new, from GM.
For LS1 which is 1997-2000 price is 189. 2001-2004 which all LS1 motors use the LS6 intake are 200. I had to replace mine on my 2001 Supercharged LS1 Corvette. I had a lean pop! :thumbsup: The metal intakes for the LS1 hold way too much heat and are heavy. The LSX intake is no more power increase then the LS6 intake for third of price!
1 - 16 of 16 Posts
