1 - 20 of 34 Posts
The Northstar Tuner
Crankshaft Position Sensor Replacement 2000 to 2005
Removal Procedure
Caution: To avoid any vehicle damage, serious personal injury or death when major components are removed from the vehicle and the vehicle is supported by a hoist, support the vehicle with jack stands at the opposite end from which the components are being removed and strap the vehicle to the hoist.
  1. Raise and support the vehicle.
  2. Remove the crankshaft sensor electrical connector. For specific CKP sensor identification, refer to CKP, EOL, EOP comploc - 2000 K .
  3. Remove the crankshaft retaining bolt.
  4. Remove the crankshaft sensor.
Installation Procedure
Important: Inspect the crankshaft sensor o-ring for wear or damage. If a problem is found, replace the o-ring.
Lubricate the crankshaft sensor o-ring with clean engine oil.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Important: Be sure to fully seat the CKP sensor into the engine block. Failure to fully seat the CKP sensor may cause a CKP sensor DTC to set.
Install the crankshaft sensor and the retaining bolt.
Tighten
Tighten the retaining bolt between 8-11N·m (70-100 lb in).
  1. Install the crankshaft sensor electrical connector.
  2. Caution: To avoid any vehicle damage, serious personal injury or death when major components are removed from the vehicle and the vehicle is supported by a hoist, support the vehicle with jack stands at the opposite end from which the components are being removed and strap the vehicle to the hoist.
  3. Lower the vehicle.
  4. Operate the engine and inspect crankshaft sensor for engine oil leaks.
  5. Perform the CKP System Variation Learn Procedure .
The Northstar Tuner
re: Northstar Crankshaft Position (CKP) Sensor replacement
That is the way GM says to do it. Now this is my way.
Raise the car on the hoist
Remove the Front Air Deflector
Remove the bolt retaining the brake line bracket to the front of the cradle
Remove the front engine mount lower bolt.
Remove both of the front cradle bolts.
Un-clip the harness from the oil filter housing
Reach up to and un-clip the reddish connector locks on each connector. I use a hook shaped pick tool.
Un-clip both connectors from the crank sensors and move them to the side.
Use a 1/4 drive 10mm flex socket and a long extension and remove the retaining bolts.
Pull out both sensors.
Slide in the new crank sensors.
Bolt them in place
Reconnect the connectors and install the locks.
Re-clip the harness in place
Reinstall the cradle bolts and the motor mount nut.
Reinstall the brake line retainer bolt
Reinstall the front air deflector
Allow the engine to warm up to operating temp.
Relearn Crank Variance
The Northstar Tuner
If you do not have a hoist and you are using ramps and if you have small arms you may be able to reach up and un-clip the sensors, But I would say to take it to the dealer because you need to have the Crank Variance relearned any way
The Northstar Tuner
Crankshaft Position System Variation Learn
Caution: Before performing the Crankshaft Position System Variation Learning Procedure always set the vehicle parking brake and block the drive wheels in order to prevent personal injury. Release the throttle immediately when the engine starts to decelerate in order to eliminate over revving the engine. Once the learn procedure is completed, the control module will return engine control to the operator and the engine will respond to the throttle position.
  1. Set the parking brake.
  2. Block the drive wheels.
  3. Ensure the hood is closed.
  4. With the scan tool, monitor for DTCs. If a DTC is set, refer to Diagnostic Trouble Code (DTC) List/Type before proceeding.
  5. Start the engine and allow engine coolant temperature to reach at least 70°C (158°F).
  6. Turn OFF the ignition.
  7. Select and enable the crankshaft position variation learn procedure with the scan tool.
  8. Start the vehicle.
  9. Apply and hold the service brake pedal firmly.
  10. Ensure the transaxle is in park.
  11. Increase accelerator pedal position until the fuel cutoff is reached at 5150 RPM. Immediately release the accelerator pedal after fuel cutoff is reached.
  12. The crankshaft position system variation compensating values are learned when the RPM decreases back to idle. If the procedure terminates.
  13. Observe DTC status for DTC P1336.
  14. If the scan tool indicates that DTC P1336 ran and passed, the crankshaft position system variation learn procedure is complete. If the scan tool indicates DTC P1336 failed or not ran, check for other DTCs. If no DTCs other than P1336 are set, repeat the crankshaft position system variation learn procedure as necessary.
The Northstar Tuner
FIGURE CKP B, CKP A, Engine Oil Pressure Switch, and Engine Oil Level Switch(c)
(1) CKP Sensor B
(2) CKP Sensor A
(3) Engine Oil Pressure Switch
(4) Engine Oil Level Switch
:confused: AJ......What would happen if you replaced the sensors but did not perform the variance relearn ???
The Northstar Tuner
Discussion Starter #8
DTC P1336 Crankshaft Position (CKP) System Variation Not Learned
Circuit Description
The crankshaft position system variation learning feature is used to calculate reference period errors caused by slight tolerance variations in the crankshaft, and the crankshaft position sensors. The calculated error allows the PCM to accurately compensate for reference period varations. This enhances the ability of the PCM to detect misfire events over a wider range of engine speed and load.
The PCM stores the crankshaft position system variation values after a learn procedure has been performed. DTC 1336 set indicates that the crankshaft position system variation values have not been stored in the PCM and the crankshaft position system variation learn procedure must be performed. The learn procedure is required after the following service procedures have been performed, regardless of whether or not DTC P1336 is set:
PCM replacement.
PCM reprogramming.
Engine replacement.
Crankshaft replacement.
Crankshaft position sensor replacement.
Any engine repair that disturbs crankshaft to crankshaft position sensor relationship.
Conditions for Running the DTC
No CMP sensor, or CKP sensor DTCs set.
The engine coolant temperature is more than 70°C (158°F).
Conditions for Setting the DTC
The crankshaft position system variation values are not stored in the PCM memory.
Action Taken When the DTC Sets
The PCM will illuminate the malfunction indicator lamp (MIL) the first time the malfunction is detected.
The PCM will store conditions which were present when the DTC set as Freeze Frame/Failure Records data.
Conditions for Clearing the MIL/DTC
The PCM will turn the MIL OFF after the third consecutive trip in which the diagnostic runs and passes.
The history DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
The DTC can be cleared by using the scan tool Clear DTC Information function.
Diagnostic Aids
The crankshaft position system variation compensating values are stored in PCM memory after a learn procedure has been performed. If the actual crankshaft position variation is not within the crankshaft position system variation compensating values stored in the PCM, DTC P0300 may set (refer to Diagnostic Aids for DTC P0300).
The Northstar Tuner
Discussion Starter #9
The Northstar Tuner
Discussion Starter #10
99 STS
Bolt them in place
Thanks AJxtcman,
I followed your proceedure on an 01 Deville last night worked like charm :yup:
It took me less than 1/2hr.
Frank
99 STS
During a learn procedure the PCM/ ECM learns the amount of crankshaft position (CKP) system variation. If a crankshaft variance relearn is not performed, then there is a chance of setting codes.
The Northstar Tuner
Discussion Starter #15
I found this on a NON GM site, but it looks correct.
NOTE: If the Crankshaft Variation Relearn is not accessible through your scan tool (some truck applications 1998 & later), perform the relearn in the following manner:
1. Turn off all of the accessories. With the Air temperature sensor and Coolant temperature within 5 degrees (Centigrade) of each other, start the engine and let it idle in Park or Neutral for two minutes.
2. Accelerate the vehicle to 55 mph at part throttle. Cruise at 55 mph for 8- 10 minutes until the engine reaches operating temperature.
3. Cruise at 55 mph for another 5-6 minutes.
4. Decelerate to 45 mph without using the brakes, and maintain 45 mph for 1 minute.
5. Perform 4 deceleration cycles, without using the brakes, of 25 seconds each where no specific speed is necessary. Returning to 45 mph for 15 seconds in between deceleration cycles.
6. Accelerate to 55 mph and cruise for 2 minutes.
7. Stop the vehicle and idle for 2 minutes with the brake applied and the transmission in Drive.
2 sevilles
Re: Northstar Crankshaft Position (CKP) Sensor replacement
While I' am a new member (I joined about a week ago) and I am definatly not a mechanic, I do have a good mechanical appitude and some decent mechanical skills. For about the last year year my Seville SLS has been stalling for no reason. As soon as I put it in nuteral and turned the key it started right up. So of course I put off taking it to the dealer. Recently it failed to start after stalling and often in the morning. I went to the cadillac forum and read about replacement of the cpk(s). I had a patient tell me why it stalled the way it did and the codes agreed. It sounded fairly simple. Last Friday I saw my last patient at about 11:15 AM So I told my receptionist not to take anymore appointments and went to the auto parts store (O'Rilley's, $102.00 for both sensors, borg warner lifetime warrenty). Took the car home. drove it up on ramps in my insulated heated garage and thought: an hour or so I'll be done.HA. I followed the procedures which I read in the forum. Everything went great...... until I started. I Took off the plastic guard under the facia,
unbolted the lines across the front frame member and lowered them, removed the oil filter and tried to remove the filter adapter. ( I did not remove any frame mount bolts)......... well for the next 30 hours (not straight thru) I struggeled with the adapter. I have many tools and I didn't have to go buy any thing I didnt have, but it was a nightmare. When I would finally find a position where I could get a wrench on a bolt..... It would only turn about an 8th of an inch. Once I finally got the adapter off and could reach the sensor connectors that was another nightmare. Once the connectors were off it was clear sailing. Sensors came out with no problem and after lubing the "O" rings with new engine oil, they went in just as easily. after new "O' rings on the adapter and reassembling everything (which seemed much easier) I put a new filter in and changed the oil with MOBIL 1. I cleaned everything up and with my girlfriend as an audience.......I prayed it would start ( I had to listen to " why don't you just take it to the dealer" for the last 30 hours) I I put the key in, hesitated, then turned it. To my great surprise it started immediatly. Had a friend use use his scanner to teach it what it needed to know. It hasn't stalled or failed to start since. IS IT A JOB FOR A BEGINNER???? I just don't know. I guess if you have a lot of time and patience you can do it. I think if I had to do it again I could do it in a couple of hours since I've learned HOW to do it. The bottom line is this: although it was frustrating at times. I felt a sense of accomplishment when I finished. MY respect and regards to all you mechanics out there. Richard L. Cushing M.D. PS: it took some time to make my hand look presentable again!
You're not the first to discover that the CKP's can be a PITA. Thanks for the writeup........
BTW...............:nanaparty::welcomeJimmyH:
2 sevilles
I just want to say that this site (Forum/owners group) is a great source of knowledge and was very helpful with my recent "PROJECT".
Keep up the good work. I'm sure I'll be visiting and posting on here OFTEN. Thanks for the great Forum.
OccDoc......... rc
'03 Deville
AJ or ANYONE who might have information...
I noticed your postings regarding the Crank Sensor problems of the series 3 Northstar motor. To make a long story short...
I bought my '03 from a freinds father who was dying of cancer last summer. It had 10.000 mile on it and was a beautiful car for the money. Anyhow I have had nothing but problems with the car not the least of which was this last problem with these sensors. Cadillac charged me $604 to replace the two sensors. I didn't seem right given I work at a sensor manufacturer and that got me thinking and browsing the internet for some answers. Anyway it seems like you know a thing or two about these sensors, the history, and what cadillac did to correct the problem. I feel as though they should have been replace for free since I see there was a letter to dealers stating as such. I understand it has bee a long time since then but they were never replaced back then because the person I bought the car from had it in storage and was ddying of cancer. Fast forward to this past week when I had the problems and the dealer never mentioned these problems they just charged the heck out of me for a replacement.
Anyway do you have more information besides what is posted here about this? I am almost sure that if Cadillac would have done the job correctly they would have told me about this KNOWN issue and made it right. Now I can not trust them or Cadillac. Can you help me with any further information/.documentation/links that might shed more light on what Cadillac did and for whom?
Thanks in advance.
John
PS did you or do you work for Cadillac?
1 - 20 of 34 Posts
