I have a 4.0L northstar in the olds aurora. I had the water pump replaced recently and the car still seems to be somewhat hot. The owners manual calls for 180 Thermostat. The car gets up to 200 in about 5-10 minutes of driving and then will stabilize if there is wind on the radiator. On the highway it gives me no problems. But in slow traffic it heats up to about 220-230. Once it got to about 235, which was too much for me. The redzone seems to start at 240 and goto 280. I know these gauges aren't always accurate but it seems to follow the following notches.
280
_Red
_Red
240
_
200
_
_
100
Anyway I've avoided idling for quite a bit and am now trying to find the problem. If there is one. The car has never overheated. I removed the thermostat last night and it seemed to help alot. The car gets to about 180 and stabilizes. If you drive it awhile then let it idle for about 5 minutes it will reach about 200-210. If you start driving again it will fall to just under 200 and then only gets hot again when you idle it. I pulled it into the garage tonight nad let it idle about another 10-15 minutes. It climbed to about 220-225 and wouldn't go much farther. However, the temp was bugging me and I couldn't let it get much closer. Is it a bad idea to run w/o a thermostat? I've always heard theyre only needed in the winter. I planned to put it back in when the outside temp isnt working against me. I've heard it can ruin fuel economy. I've been watching my avg mph on the vic and it hasn't changed. Car seems to be running well. It gets up to 180 in about 5-10 minutes of running. That seems average to me. Is there anything else dangerous about running w/o a thermostat? I've heard the coolant can be moving "too fast". If this is the case would re installing just the housing to the thermostat slow it down?? Do thermostats stick? I boiled this one and it opened...Not sure about what temp it opened at though.
Any help would be GREATLY appreciated.
280
_Red
_Red
240
_
200
_
_
100
