1 - 20 of 63 Posts
:burn:Here's my problem I'm currently swapping a northstar V8 into a 90 Chevy Beretta. I've already modified the front end of the car to accept the motor by moving the front frame rails over 1.75 inch on both sides to make the engine bay wider, notching the strut towers, welding in a strut tower brace that extends to both strut towers and the fire wall, moving the radiator, welding in a forward brace to bolt the stock torque strut motor mounts to, reinforcing the front end and making provisions to bolt up the engine cradle from a Cadillac Seville. I'm still working lower control arm and axels but I'll get to that later. I'm using engine, complete engine wiring harness, PCM, alternator, power steering pump ac compressor, all the sensors, and the engine cradle from a 94 Cadillac Seville SLS vin#Y. My question is what to do with some of the wiring. I'm trying to spice the caddy harness into the beretta chassie harness. The to main connectors that run from the engine harness to the chassie are connectors numbers C101 and C203.I have chassie end of these connectors as well. I've know what to do with most of the wiring but some of it i'm still confusued about. Qustion one is will this pcm set a code if it can't send an output signal to the RSS module through pin 3F11 on connector 3E/3F(blue PCM connector). There is also a vehicle speed out put to the rss module through pin 1B12 on connector 1A/1B (red PCM connctor).can this be disconnected? Question two, there is also a U.A.R.T data line that runs from pin 2C12 and 2C13 on connector 2C/2D (white PCM connector) to pin Y on C203,circuit 800. Is this only for pulling code using the onboard diognostics through the climate controls or dose it have another purpose, will it set a code if I don't connect it Question three. .dose Gm offer any calibrations that might work for this setup. I have a vetronics 5100 mastertech scaner with a a GM SPS programing card so flashing the PCM is not a problem. I want to use a 5speed out of a 3.1 V6 cavilier. It will bolt up to the northstar with a some modification to the upper bellhousing to clear the starter because both use the 60 degree gm bellhousing patturn. I sent an e-mail to the guys at Cadillac Hotrod Fabricators ( www.chrfab.com ) and they told me that they have a flywheel, pressure plate, and clutch that will work with this setup.
Also dose anyone make an aftermarket computer that might work for this setup.
thanks in advance for any help
I hope to have pictures up soon
:burn:
94 ETC,97 STS
I am impressed!!!!
Sorry I can't help you with the wiring, you really need the factory manual.
What is the difference in track between the Beretta and the Caddy?
OmG!! hehe.. i can't believe u are putting it in that car.. isn't it like 1000 lbs lighter than the SLS :) It will FLlllllllyyyyyyy
I could help if i was there but something like this I can't even begin to picture it over the internet :)
PLEASE UPDATE YOUR HOTMAIL EMAIL ADDRESS. IT NEVER
94 GTP RWD N*
Mmmmmmmmmmm N* power
I love to see your ambition!! I know we will become good friends and swap a lot of info as soon as you hear my project outline! lol
A rear wheeled POSI 10 bolt 8.5 in. Buick GN turbo, powered by a 93-96 Northstar in my already custom 5 speed 1994 Pontiac Grand Prix (they didnt make my 94 in a 5 speed)
My grandpa has worked for a local Caddy dealer for close to 50 years, so I grew up with Caddy's. He's owned 34 cadillacs so far in his lifetime (and counting)
The reason I chose this motor for my swap is, because it is a smooth sophisticated low hoodlined motor. I chose the Grand National rear end because of the torque it can withhold. The front suspension I was thinking of using was a 93-01 Firebird, so that I get my RWD configuration. The suspension travel is 2" less than my GP so my car will be 2" lowered in front with a stock F-body front end.
http://www.chrfab.com/Transmissions.htm said that a stick shift Camaro/Firebird bellhousing will bolt right up.
I am still debating on a transmission but leaning toward a Tremec 3550, Tremec 3650 or 6-speed T-56.
Does anyone have any links to mustle car transmissions specifications?
Thank you for reading and/or responding everyone,
Travis U.
Milwaukee, WI
94 GTP RWD N*
now for your help request......
GM does not have anything for this. The performance guys barely have anything for this unless you go with the Comander 950 stand alone computer system ($1300 from chrfab.com). There is a guy that I know of in MI I believe, that does do N* PCM reprogramming for 93-96 computers. He only has a 275HP (Vin Y) configurations set right now. He cant get the 300HP correct yet (as of 3 months ago so you never know). One more thing to add about the computer this guy reprograms is that it is ENGINE MANAGEMENT ONLY, meaning no ABS, no PassKey or PassKey II, no nothing, engine only.
On to the transmission. Your tranny will bolt up to that bolt pattern. BUT your Getrag HM-282 is only rated for a 200something Torque. I have a HM-284 (stock in 91-93 3.4L DOHC Grand Prix's) in my 1994 Grand Prix GTP :) :) :) www.cardomain.com/id/soccrplayrgtp if are interested in takin a look. I am currently beating the shit out of my Getrag 284/ 3.4L DOHC 210HP and the tranny is not doing so well. They MAY be rated up to 400lbs TQ but there is no documentation I've found yet. Just hear say. So until then I'm sticking with 280lbs/tq which I can tell :)
Travis
customGTP said:
The 4t60-e/ 4t65-e can handle the N* quite well and the obd1 computer can also be done quite easily. The obd2 caddy computer can be reprogrammed and the Aurora obd2 is also coming along. Yes including VATs and all.
I hear the 4t80-e takes on the N* like it was meant to fit. I guess there was no room? lol
The 4t60-e can take on 400lbs of torque and 600hp is not an issue with a properly built bulletproof unit.
You can also get a limited slip for all of the above.
For motor mounts try adding limiters that kick in at 3/4 load on the mounts.
Ty
94 GTP RWD N*
hey Ty did you get my phone message? lol
How much is it for you guys to reprogram a OBDI PCM??
VATS PASSKEY AND ALL? not only engine management? Tell me more Ty!!!
No did not get the phone message. When did you send it? My secretary is slow... lol
Now as for the rest I will take care of it privately and post other info properly I don’t want to pollute the forum.
Ty
Discussion Starter · #10 ·
On to the transmission. Your tranny will bolt up to that bolt pattern. BUT your Getrag HM-282 is only rated for a 200something Torque. I have a HM-284 (stock in 91-93 3.4L DOHC Grand Prix's) in my 1994 Grand Prix GTP :) :) :) http://www.cardomain.com/id/soccrplayrgtp if are interested in takin a look. I am currently beating the shit out of my Getrag 284/ 3.4L DOHC 210HP and the tranny is not doing so well. They MAY be rated up to 400lbs TQ but there is no documentation I've found yet. Just hear say. So until then I'm sticking with 280lbs/tq which I can tell :)
Travis
thanks for the info i would have replied sooner but my computer decided it didn't want to work for the past week..:banghead2
i checked out your site and i like your work it gave me a lot of ideas and insite on some potental problems i might have with my project
Discussion Starter · #11 ·
Re: Mmmmmmmmmmm N* power
sounds like a cool project .I like to see some pictures of it when you get the car together good luck:)
90 Fleetwood Coupe, 90 Deville Limo, 05 STS, 81 DMC w/North*
hi
I am currently In the process of dropping a 2001 Vin 9 Northstar into my '81 DeLorean. I too was puzzled by the wiring, but I found a guy in CA who will take the entire wiring harness and convert it to a 4 wire setup, meaning all you have to do is power 4 wires and your good to go. I cant say for sure if he does quality work or not, cause im still waiting on my harness to get back. if you want though, check out http://www.dynatechmotorsports.com . once I get my harness back I will let you know what I think.
Good Luck with the conversion
Tony
Interested in any help with a Northstar transplant, especially in the wiring and computer area. Does "Speedy" have the ability to reprogram the ECU? Also interested in the 4-wire harness, sounds nice and easy! Thanks
customGTP said:
where are you located?? I can help with whatever I can
I'm located in Monterey, CA area and I really need help with the chip part. I called Fastchip and they don't handle the Northstar anymore. I want to be able to have the engine standalone on the chip since I will not be using an automatic. Also, I called Dynatech about the wiring harness and it takes about 3 weeks and +/-$200 to modify your engine wiring harness. And I called McLeod's and they are getting ready to do a manufacturing run on a dual disc clutch and flywheel. If they get more orders for them, the price is supposed to be close to $650 (flywheel and all clutch parts). This will help with handling torque since the diameter is soo small (9 11/16"). McLeod is also making a modular bellhousing that can convert to all sorts of transmissions. Let me know about the chip! Thanks
Yes OBD1 is mastered for the caddy.
We continue to offer only certain years for the obd2 caddy and "had" a finish date of November the 30th for the Aurora obd2 reprogram but hardware shipping slowed it down a bit. A new date is coming.
Actually the obd2 reprogramming extraction and reprogram is fairly easy.. lol its getting it back on the computer and working that can be problematic.
We can also do custom computers so if you are interested in a swap and want the caddy computer to talk to a Fiero we can help.
Ty
1999 Northstar in a 1986 MR2
DeLorean_Northstar said:
hi
Tony
Do you have an update on this harness? I am new here and thank Google!!! for helping me find this place. I too am doing a Northstar swap. I am installing mine into the back of a 1987 Toyota MR2. The engine fits with some slight :) metal cutting. But I am really interested in the modified harness.
More info about my car is found here -
http://www.racingstrong.com/toystar/index.asp
Bill Strong
Owner
The Toyota MR2 Owners Club Message Board
Over 10,000 Registered Users!
http://www.mr2oc.com
Discussion Starter · #18 ·
Bill Strong
Owner
http://www.mr2oc.com[/QUOTE]
Thanks for all the info on your site, the pdf's are really going help, the more info the better. I don,t think the wiring will be that bad, just getting the PCM to ignore the other control modules in the car that,s the problem I ran in to.:banana:
Discussion Starter · #19 ·
Ty
this is what I've been looking for, can you give me some pricing info and how to contact your company. Thanks in advance for any help EPAnightmare
Yeah, me too!! I need info on the chip programing and how to contact you. I have an ecu from a 94 Northstar with a 1993 engine. The engine is the 300 hp version and I'm pretty sure the ecu is too. I don't have the vin from the 93 car, however, I do have all the numbers on the engine. The only other option was going to be using a Holley Commander 950. My e-mail is [email protected]
1 - 20 of 63 Posts
