1 - 2 of 2 Posts
07 Escalade
Does anyone know what is the normal operating temperature of the 2007 Escalade transmission? I have the AWD. The range varies from 145 degrees to 195 depending on speed and outside temp. What is consider too hot for the transmission?
2012 Escalade, 2014 SRX
The trans has synthetic fluid, so under 250 degrees you will be fine, the temp will never get that high, I have towed in 100 degree heat and the trans was up to 210 for a high at one point of the trip in the mountains.
1 - 2 of 2 Posts
