2001 DHS
Does anyone here have any experience with non GM headlights for the Deville? Are they as good as the originals? If not what are the drawbacks?
if you are asking about the actual headlight housing -
I would use great caution if you are considering cheap aftermarket units -
they may fit OK -
but they might not perform as well -
if the reflectors aren't EXACTLY the same as OEM -
they might not focus the light properly -
now - the REAL question -
WHY? - what's wrong with your headlights?
2001 DHS
My headlight have these cracks on them. As for the light reflections you mentioned, I have projectors retrofitted so it shouldn't really matter or should it would you say?
If you retrofit projectors into the housings, the reflectors won't be doing anything.
so - what do you want to do -
do you want to simply get rid of what you have now -
and go back to the stock halogen bulb system -
or do you want to try to replace the cracked lens
on your existing - modified - set-up
Aftermarket light assembly parts usually don't interchange with OEM housing parts.
