Rear pads are worn down on my 1995 Concours so I bought a set of pads from Advance. I have the rear brakes all taken apart on the driveway, and notice the rotors aren't perfectly smooth(can feel slight difference when running finger across them). So I called Advance to see if they stock rotors and no stores had them or could order them. Next I looked up the rotors on Rock auto and see that there's an AC Delco rotor listed in the "economy" list for $17.79 each (p.n. 18A488A), and another AC Delco rotor listed in the "heavy duty" list for $29.79 each (p.n. 18A488). Both list the same dimensions, but the more expensive rotor says "supplied in o.e. noise dampening iron", and the cheaper one does not. Other than that, the only difference is the more expensive rotor has a black coating on the center.
Are both these rotors actually noise dampening iron but the cheaper ones just don't say that? Does this 1995 deville/concours need it to be noise dampening iron? I'd just like to put on the direct o.e. replacement if I'm going to order online anyway.. and even the $29.79 price rotors are affordable for me right now. BUT which are stock?
If it matters.. the brakes on the car were working but starting to make noise because pads wore down. Parking brake works and I use it every day. just hit 100,000 miles.
