1 - 14 of 14 Posts
04 Cadillac CTS-V...1996 Camaro SS w/500hp
Well, this morning I get in the car and put my iPod in the craddle and go to change it to XM and I now go right from FM to AM and no XM on the presets? I check the box up front and everything looks OK.
Has anyone had this problem before? I will tear into the package tray and check things there but nothing has changed at all? :banghead:
CTS-V
Pull the negative battery terminal for a few seconds and try again. The Neo has an attitude sometimes, honestly. I have had this problem numerous times, and pulling the negaive battery terminal is the only thing I have found that fixes the problem, but only temporarily.
2004 Cts-v
I'm having the same problem as well with the USA spec adapter. Going to pull the cable tonight, but wary, b/c Im not sure if I will lose my user preferences, like seat setting, etc?!
CTS-V
You will lose your seat settings, clock, etc. Its a pain in the a$$. But its the only way I have found to make the XM channels come back on. Once you reset it, just long press seat # 1 until you hear the beep. Then its reset.:)
Discussion Starter #6 (Edited)
turn the car off wait 5 minutes and try again....should fix your problem.
Yeah, that didn't work for me...XM popped back on for 2 sec and then went right back out again.
Wow that sucks...i have it installed on the car for 1-1.5years and never had this problem before...hopefully it doesn't start a trend.
2004 Cts-v
Bummer, it took me way too long to figure out my seating postion in this car!!!
Same for me, XM came back on for a few seconds once, then gone for good again?! Supposedly theres a defective XM unit on some of our cars, that could be the culprit, but hopefully the battery reset will work!
Discussion Starter #8
well, I pulled the main cable apart under my seat and left the car off until lunch time and them when I got back in everything was fine. The cable didn't feel loose but it working again without unhooking the neg battery so who knows?
2004 Cts-v
Hmm...so you just unplugged the cable from the XM unit to the NEO unit, and it fixed it? Interesting. I will try the same tonight.
Discussion Starter #10
Well, its the main cable running from the package tray up to the front unit. I have a extentsion cable that runs the NEO box up under the drivers seat. I unplugged that main splice and it reset it somehow. I trying unplugging everything on the NEO box and that didn't work.
2004 Cts-v
I unplugged the smaller blue wire running to the USA Spec unit, and sure enough ,I heard a small click from the rear deck, then bam...XM stations show up again, and unit works normally!
I sure am glad I didn't install the USA Spec unit under the rear deck!
Discussion Starter #12
Glad you figured it out without tearing apart the rear deck. Sounds like the units need to be reset everyonce in a while. Hopefully it doesn't happen all the time as some people have stated.
'05 CTS-V
I sometimes have the same problem with the XM and my car is completely stock. I'll crank it and there is no XM to be seen cycling through the bands. I can turn the car off for a few minutes, then start it back up, and the XM returns. Is this a common problem?
2004 Cts-v
It sounds like it happens to some people. It's like the cars data bus is out of bandwidth and Im assuming thats what causes the issue. I know you cant program the car with a diablosport while the the USA Spec unit is attached...it times out. :banghead:
1 - 14 of 14 Posts
