21 - 24 of 24 Posts
The only time I ever dealt with an engine that wouldn't pump coolant, was an Olds engine with a stamped sheet-metal water pump impeller.
The impeller had rusted so badly that it separated from the pump shaft. Water pump shaft turned, impeller didn't. Therefore, no coolant flow.
Discussion Starter #22
It helps to read the entire post. 3 different new water pumps,2 different manufactures.I have been doing this fo 60 years and never seen anything like this.Can't afford a $2000 rebuild and been looking for running used for 2 months
I did read the entire post. I'm aware that you've dicked with the water pump. I'm telling you that the only time I ever had that problem...it was the water pump.
Discussion Starter #24
Sorry,it's that i've told this story for 3 months and most just want to quote a Chilton manual to me. I am 73 and will try anything to keep from swapping out motors. Thanks for trying
21 - 24 of 24 Posts
