I have an 03 Cadillac Escalade that seems to have an extensive wiring issue, dealt with a lot of the problems now what problems exist are my vanity lights, driver & passenger mirror lights, and rear cargo lights no longer turn on
I also have been having an issue with the dome lights, it has the dome lights above the mirror and the dome lights in the center
when I turn on the dome lights off the dial they all come on super bright the way they should
But the middle row domes L&R bulbs don’t turn on, you manually have to do it and when they come on they’re dim and I have bright ass LEDs installed
when you turn them on the front dome lights turn off or dim.
thing is.....it’s always in a different pattern, which is irritating as all hell
so what worked one day doesn’t work the next and you have to figure out a sequence of pressing them so they all work the way they should.
I’ve checked fuses and my fuses seem to be good but I can’t find anything for the rear cargo, and again the fuses are all good, is there some that I could potentially be missing?
Ohhhh and my rpm needle is buried at 6000
And some lights also don’t work there
any help is greatly appreciated!!!
Thanks in advance🤙
Thanks in advance🤙
