96 Deville 01 Deville DTS
Last Night i was Re-installing my radiator cooling fans and i had to disconnect the top transmission coooler line from the radiator to get it in, well long story short i started it up without reconnecting that cooler line and there is a huge puddle of ATF in the drive way FML I didnt drive it it just sat and idle for about 30 mins. Did i screw up my transmission???
1985 Sedan DeVille
pump ran dry, you could have cooked something
........... and refill it correctly. If it idled for 30 minutes you pumped out about 13 quarts of fluid - ????? BIG puddle. Where were you the entire time ?
Pour in about 7 quarts and let the engine idle on a level surface in P. Begin checking cold fluid level and gradually bring it up to the COLD FULL level. Install the dipstick and go for a 15 mile drive. Come back to the same level surface, in P, and adjust flud level to the middle of the FULL HOT hashmark. Triple check the transmission oil cooler fittings at the radiator for absolute zero leakage.
DO NOT try to check/adjust fluid levels with the engine OFF.
only one way to tell -
fill it up - and pray -
The car (96 Deville) Had been sitting for a while and the battery died i had some parts to change under the hood, did that then jumped if off and let it run to charge the
battery. I didn't notice it leaking it was dark out I should have double checked everything before starting on a good note the fluid looked red and clean LOL
