I post this so maybe It will help someone from spending $599.00 for a dealer fix.
Turn key, display lights as normal, but no crank in start position..Turns out to be a bad ground UNDER THE FUSE BOX..in the engine
compartment..
Also when a dtc does comes up...don't fix anything until you have first cleaned that components connector plugs with an electrical contact spray cleaner...
Electrical problems abound..
Good luck
Henry1940
compartment..
Good luck
Henry1940
