92 Fleetwood 4.9L. Just replaced engine with used 4.9L engine, original one seized up from head gasket leak and overheating. Install went well, used new Distributor, coil, cap, plugs, etc. Engine turns over fine, sounds like it wants run, but there is no spark. I set TDC on #1 cylinder set rotor to #1 plug, jumped A&B on adl conector etc etc just as the shop manual says to. Only trouble code is e55 tps out of range. Yes there is fuel pressure. Any sugestions would be greatly appreciated.
