21 - 23 of 23 Posts
Thank you for
Do you get the door chime sound?
If you get the door chime the amp is likely working and something is wrong with the radio or between the amp and the radio.
If you do not get the door chime check the amp, behind the trunk lining, back driver side corner.
this info,
Thank you for the info. I had the same issue. No sound from the radio, no chimes when seatbelt unbuckled, trunk or door open or the start of ignition. Bought an amp on ebay for $65 for the same GMC part number. Just installed it now and it worked!
Now to get the outlet to work. I’ve verified the fuses under the hood and under the backseat and no luck.
21 - 23 of 23 Posts
