1 - 20 of 23 Posts
i get into my car today and radio turns on but no sound.
i was thinking of trying to disconnect the battery see if that rests everything.
anyone have a clue of what might be going on.
thanks
2004 CTS-V
Do you get the door chime sound?
If you get the door chime the amp is likely working and something is wrong with the radio or between the amp and the radio.
If you do not get the door chime check the amp, behind the trunk lining, back driver side corner.
ok i get back into my car this afternoon and go out for lunch and poof radio is blasting on hi volume cause of me trying to get it to amplify anything. now here is the funny thing i drive back to work and the radio shuts down. i do hear static before the radio volume cuts out.
2007 CTS-V (Thunder Grey)
I have a similar problem in my Corvette. I stopped to get gas one day and when I started the car again the radio was dead, no chimes or anything. Then the next day I was on the way to the audio shop and all of a sudden it started blaring. It worked while I was at the audio shop then when I was 5 miles down the road it went dead again. Onstar doesn't even work correctly, they eventually answer but I can hardly hear them. Whewn I press the emergency button I get a mssage that Onstar in not active... It has to be a lose connection somewhere... I will have them check everything in a couple of weeks...
please let me know what you find out
is the onstar on the V' in the trunk
i wonder if the cable is loose??
04' Blown CTS-V 554rwhp 497rwtq
Yes. Passengers side closest to the taillight area if I remember correctly, although I don't think that is YOUR problem but who knows. G/L
78 Deville 10 CTS-V Sedan M6 10 SRX Turbo Premium
Mine used to have this problem. Radio would work fine, park the car and get back in it and no sound, not even a door chime.
Here is how I fixed mine:
If you wait until it happens again:
1. Turn the parking lights on and leave the door open (this would normally cause the door chime to sound.)
2. Remove the trim around the trunk latch
3. Remove the cargo net hold-downs on the left (Driver's Side)
4. Pull the carpet back exposing the radio amp.
5. Slowly wiggle the harness plugged in at the bottom of your amp.
6. If yours is like mine, you will hear a click and then sound from your speakers.
If step 6 is correct, remove the amp look at each pin that feeds into the amp. One of the pins on my amp was slightly bent causing a bad connection. I am thinking this was caused by the stress the harness puts on the amp at the connection. GM really made the wiring harness to short which caused the plug to plug in at a weird angle.
If step 6 doesn’t work, I don’t know what to tell you! :hmm:
1997 Deville D'elegance
Hi; I’m trying to get my radio to work before I tackle the head gaskets issue.
I just removed the after market radio from my 97 Deville D’elegance and installed an original am/fm cassette. All the wires and connections are there. I’m getting power to the radio, antenna goes up and down like it should, but I’m not getting any sounds. I’m suspecting a bad amp since I’m not getting any sounds from the door chime either. I tried moving the wires with the door open and park lights on but the chime never came on. How can I test the amp? There are two boxes, one is the amp and the other silver square one where the speakers are connected to is?
Thanks!
deville DHS 2007
I have a 2007 DHS radio with no sound, and like previous posts, it can come and go will no warning. Also no sound from blinkers, and "parking Assist off" displays on the dashboard. The car has been "possessed" which started with complete failure of the electrical system, and had to be towed to the dealer. After 7 months of replacing "computer modules" (drivers side mirror, rear view mirror, passenger seat air bag module, XM radio module), the car starts, but this radio sound problem exists, the dealer now says it is the "radio" and wants to replace it for $2,400! Looking for some answers.
2007 Cadillac CTS
Hello - and Thanks for any advice you can give.
I have a similar problem but not exactly as described here. Desperately looking for a solution.
I have a 2007 Cadillac CTS. 53k miles.
The amp is the ac delco 15845424.
On Star - not active
No Navigation
Problem:
- Start Car
- Turn on Radio - everything works wonderfully. No issues, soft, loud, CD's, Door Chimes - everything works.
- 1 to 2 minutes later - no sounds at all. Radio is full functional, change stations, change bands, go into setup etc.
- no door chimes
- Turn off Car - immediately turn back on, same problem - no sound
- Wait about 1/2 hour - system is back to normal
- 1 - 2 minutes later - no sound
- I can repeat this as many times as I want - does the same thing.
What I have done so far:
- Swapped the 30amp fuse out - used the 30 amp fuse from the Power Sunroof
- Jiggled all the wires going into the amp - bottom and top while problem is occurring - no clicks or sounds from speakers at all
Could it be a faulty amp? Would hate to buy a replacement and have the same issue.
Anything I can test?
Thanks very much.
No Navigation
Problem:
- Start Car
- no door chimes
Thanks very much.
Hello Tekkens,
Welcome to the forum! I am sorry you are experiencing issues with your CTS. I see you have tried resolving this concern and are reaching out to other forum members for their advice. If you would like to further discuss this concern with us, please reach out via private message or by Email at [email protected]. Please include your contact information, VIN and current mileage in the message.
Sincerely,
Laura M.
Cadillac Customer Care
17 xt5 & Blk 05 cts-v
Anyone find a solution to this? Even after putting in a new amp I have no sound. Everything works but no sound.
2007 Cadillac CTS
The amp replacement fixed it for me, can you tell if the amp is getting power? If not, the fuses for it are under the back seat. You need to remove the back seat cushion
and check them. Could be as simple as a blown fuse.
Best,
Fuse is good. I looked for any loose wires. Nothing seen. I already looked at the connection to the amp. Even changed the amp. Nothing so far.
What's you make and year again?
I have this problem every couple of months. Like the other subscriber stated , GM made the harness too short and causes stress at the connections . Push all connections in 1 by 1 and attach harness with strap to car to give slack
Mine ended up being the remote wire. I hand to run a new one from a new location. Don't know why the other was bad but it was.
1 - 20 of 23 Posts
