2016 Cadillac Vsport
Just called D3 and they do not make lowering springs for the Vsport anymore. Any options now?
2017 CTS V Sport, 2007 3.6 CTS
Had 2009 V, Red/Blk 2016 Now
Mine are so sagged, I wouldn't want to go any lower.
Sagged springs are usually bad springs, maybe time for a replacement set, unless they work better for you then new springs. :)
On a side note if your looking for stock replacement parts always go to the two main sources I know of: GM parts directs and GM parts outlet, especially for common wear items like brake rotors because of the hardening process used. Very off topic; but (youse guys) (my best cousin Vinny impersonation) with hub flange run out maybe try a little grease between the hub and rotor hat ( to help prevent corrosion) after you replace the hub after a brake job. This advice is coming for a non expert in this area, just my two cents.
